Okuma OSP-P300S/P300L Alarm-C list.
For cnc machinists who work on cnc machines with Okuma cnc controls.
Classification Of Okuma Alarms
Alarms related with the OSP are classified into five types, which are
Below are listed Okuma C type alarms for Okuma OSP-P300S/P300L CNC systems.
Okuma Alarm C List
- 3055 Device temperature too high
- 3056 Non-functioning device detected
- 3057 Unable to start during virus scan
- 3120 Overload detected.
- 3122 Maintenance (by user) necessary
- 3132 VDU communication error
- 3133 VDU detected error
- 3134 VDU initialization failure
- 3135 MCS DD encoder link error
- 3136 MCS DD Encoder error
- 3137 MCS DD Encoder (slave sensor) error
- 3138 MCS DD encoder initialization failure
- 3139 MCS DD encoder (slave sensor) initialization failure
- 3144 MCS Power supply unit overload
- 3150 MCS Undefined alarm number
- 3151 MCS Inverter unit fault
- 3152 Mistake in data from MCS to NC
- 3153 MCS CON APA deviation
- 3154 MCS Power supply unit error
- 3155 MCS Converter link error
- 3156 MCS DC-bus voltage alarm
- 3157 MCS Motor overcurrent
- 3158 MCS Power unit overheat
- 3159 MCS Power unit overload
- 3160 MCS Supply voltage flutter
- 3161 MCS Inverter capacity differs from spec.
- 3162 MCS Winding change failure
- 3163 MCS Encoder link error
- 3164 MCS Encoder detected error.
- 3165 MCS Encoder initialization failure
- 3166 MCS Encoder with shaft detected error
- 3167 MCS Encoder with shaft initialization failure
- 3168 MCS ABSO SCALE error
- 3169 MCS ABSO SCALE initialization failure
- 3170 MCS Magnetic encoder alarm
- 3171 MCS Resolver alarm
- 3172 MCS Pulse generator count over
- 3173 MCS Motor overheat
- 3174 MCS Servo link error
- 3175 MCS Servo link disconnection
- 3176 Mistake in data from NC to MCS
- 3177 MCS Servo data error
- 3178 MCS Illegal command
- 3179 MCS CON speed over
- 3180 MCS Speed command over
- 3181 MCS DIFF over
- 3182 MCS APA speed over
- 3183 MCS Full-closed APA error
- 3184 MCS Over speed
- 3185 MCS Speed deviation over
- 3186 MCS Collision detected
- 3187 MCS Urgent-stop time over
- 3188 MCS Belt is broken
- 3189 MCS Axis change control error
- 3190 MCS Independent encoder initialization failure
- 3191 MCS Calculated current position lies outside range
- 3192 MCS Motor overload
- 3194 MCS ABSO SCALE sub-slider detected error
- 3195 MCS Tandem control communication error
- 3196 MCS Full abso scale link error
- 3197 MCS Full abso scale error
- 3198 MCS Full abso scale initialization failure
- 3199 MCS Axis stop signal error
- 3202 User reserve code
- 3203 Warm up run
- 3204 Running time over
- 3205 Work counter over
- 3206 Cycle time over
- 3207 DNC Start conditions
- 3208 DNC Initialization sequence impossible
- 3209 DNC Illegal text from host
- 3210 DNC Incorrect machine No.
- 3211 DNC Text format error
- 3212 DNC Text receipt error
- 3213 DNC Text transmission error
- 3214 FMS Coupling mode change
- 3215 FMS HOST CPU alarm
- 3216 FMS Operation mode select
- 3217 DNC-B buffer operation
- 3218 DNC-B buffer operation change
- 3226 Common unit illegal
- 3231 Program select
- 3232 Load monitor overload
- 3238 ROBOT alarm/reset
- 3240 LOADER alarm/reset
- 3241 Post-process gauging Unable to transmit
- 3242 Post-process gauging Unable to receive
- 3243 Post-process gauging Time out
- 3244 Post-process gauging Data format error
- 3245 Gauging data out
- 3246 CEJ MATIC Data NG
- 3247 CEJ MATIC Data read
- 3248 Size catcher Data NG
- 3249 Size catcher Gauging error
- 3250 Size catcher Unable to transmit
- 3251 Size catcher Unable to receive
- 3252 Size catcher Time out
- 3253 Size catcher Data format error
- 3254 Schedule program start
- 3255 Main program start
- 3261 Tool life management No spare tool.
- 3264 RS-232C communication illegal
- 3266 Workpiece counter full count
- 3271 Gauging sensor battery change
- 3279 DNC Machining start conditions
- 3280 DNC Data receipt start conditions
- 3289 Load monitor low load
- 3295 Quality check alarm
- 3300 Tool data output
- 3314 External tool offset input
- 3316 Position encoder adjustment required.
- 3319 DNC Ethernet receipt command not allowed.
- 3320 DNC Ethernet receipt error
- 3321 DNC Ethernet transmission error
- 3331 NC tailstock position error
- 3332 Reboot machine.
- 3682 Magnetic encoder speed detection error
- 3683 MCS Rotary encoder 5 initialization failure
- 3684 MCS Rotary encoder 5 error
- 3685 MCS Rotary encoder 4 initialization failure
- 3686 MCS Rotary encoder 4 error
- 3687 MCS Rotary encoder 3 initialization failure
- 3688 MCS Rotary encoder 3 error
- 3689 MCS Rotary encoder 2 error
- 3690 MCS Rotary encoder 1 initialization failure
- 3691 MCS Rotary encoder 1 error
- 3692 MCS Linear scale 4 initialization failure
- 3693 MCS Linear scale 4 error
- 3694 MCS Linear scale 3 initialization failure
- 3695 MCS Linear scale 3 error
- 3696 MCS Linear scale 2 initialization failure
- 3697 MCS Linear scale 2 error
- 3698 MCS Linear scale 1 initialization failure
- 3699 MCS Linear scale 1 error
- 3700 Power save ON
- 3701 CPU temperature
- 3702 Warm up run
- 3703 Oil filter
- 3704 Lube tank flow
- 3705 Lube tank level
- 3706 Spindle lube pressure
- 3707 Spindle cooler error
- 3708 Oil cooler error
- 3709 Coolant level
- 3710 Air blow pressure
- 3711 Air pressure
- 3712 Program selection interlock
- 3713 Chip conveyer overload
- 3714 ZA-axis overload
- 3715 ZB-axis overload
- 3716 XA-axis overload
- 3717 XB-axis overload
- 3718 Coupling device error
- 3719 ROBOT control
- 3720 ROBOT alarm/reset
- 3721 ROBOT/LOADER control
- 3722 LOADER alarm/reset
- 3723 Schedule program start
- 3724 Main program start
- 3725 CEJ MATIC data NG
- 3726 CEJ MATIC data read
- 3727 Auto power off impossible
- 3728 Oil cooler level
- 3729 Coolant error
- 3730 Coolant flow
- 3731 Coolant abnormal
- 3732 Robot/loader axis safety speed over
- 3733 Robot/loader safety speed monitor error
- 3734 ATC step time over
- 3735 Next tool preparation impossible
- 3736 Coolant filter
- 3737 Mist collector
- 3738 Mode switch operation prohibited
- 3739 Control box air conditioner error
- 3740 Air filter clogged
- 3741 Index chuck oil level
- 3742 ATC-axis circuit breaker
- 3743 ATC-axis motor overload
- 3744 Chucking miss air
- 3745 Mist lubrication unit
- 3746 External start switch
- 3747 NC start button
- 3748 Door sensor
- 3749 Automatic lubrication system error
- 3750 Tailstock absolute encoder error
- 3751 Invalid external tool offset input
- 3752 Coolant supply
- 3753 Drain tank
- 3754 Mist collector
- 3755 Workpiece conveyor error
- 3756 Unmachined workpiece detection
- 3757 Bar feeder error
- 3758 Oil mist error
- 3759 Tool monitoring unit error detection
- 3760 Fan cooling unit pressure
- 3761 TOOL change not possible
- 3762 ACC step time over
- 3763 Switch disabled
- 3764 Oil controller unit
- 3765 Spindle vibration sensor
- 3766 Coupling device interlock
- 3767 Tailstock holding miss check air
- 3768 Irregular coolant level
- 3769 Side cover open
- 3770 Safety door open
- 3771 Lube tank motor run time over
- 3772 Coolant flow
- 3773 Earthquake detected
- 3774 EC circuit breaker
- 3775 Lubrication unit error
- 3777 Air blow flow
- 3778 M axis cooling fan overload
- 3779 APC system conditions
- 3780 Touch setter unit error
- 3781 EC overload
- 3782 Sensor contact signal error
- 3783 ATC interlock
- 3784 Fire extinguish unit power OFF
- 3785 Spindle lubrication unit
- 3786 Chip flush-out motor overload
- 3787 M-axis unit command mismatch
- 3788 AAC system condition
- 3789 Air dryer unit error
- 3790 Ext. program select parity check
- 3791 Mist air lubrication unit
- 3792 Chucking miss
- 3793 Coolant level low
- 3794 Power source unit overload
- 3795 Hydraulic oil unit
- 3796 RSS unit battery error
- 3797 RSS unit communication error
- 3798 Unloader interlock
- 3800 Transfer data error
- 3843 Safety fence open
- 3844 Invalid loader grease lubrication input
- 3845 Coolant level lower limit
- 3846 M/C panel at interfering position
- 3847 Invalid limit/proximity switch
- 3848 Anti-gouge unit faulty
- 3849 Tool counter full count
- 3850 External alarm
- 3851 Tool counter faulty
- 3852 Tail stock chuck position
- 3853 Invalid loader limit/proximity switch
- 3854 Chip conveyor stop
- 3855 Oil air unit oil level low
- 3856 Coolant motor overload
- 3857 Oil skimmer overload
- 3858 Chuck grip confirmation unit faulty
- 3859 Fire extinguisher error
- 3860 Fire extinguisher power OFF or error
- 3861 Chip conveyer filter clogged
- 3862 Filtration unit error
- 3874 Sub chip conveyor error
- 3875 Absolute encoder controller error
- 3876 Workpiece loading unit stop signal ON
- 3877 Workpiece counter full count
- 3878 Concentrated chip conveyor
- 3879 Gauging NG
- 3880 Spindle air purge pressure
- 3881 Turnover cycle time over
- 3882 Start impossible
- 3883 Chip crusher error
- 3884 Workpiece puller operation incomplete
- 3885 No workpiece
- 3886 Workpiece present
- 3887 Temperature control unit error
- 3888 Chip conveyor faulty
- 3889 EExternal start signal ON
- 3890 Low level in oil tank
- 3891 Multi-counter tool life
- 3892 Hydraulic oil level lower limit
- 3893 Hydraulic unit oil controller
- 3894 Spindle lubrication controller error
- 3895 Coolant controller error
- 3896 Tool change count-up
- 3897 Workpiece stocker full
- 3898 Cooler error
- 3900 User reserve code
- 3901 External
