Complete Centroid CNC Alarms Errors Messages for CNC machinists who work on cnc mill/lathe machines with Centroid cnc control (T-series/M-series).
Centroid Alarms Errors Messages
Contents
- Centroid CNC Alarms Errors Messages
- CNC software startup errors and messages
- Messages issued upon exit from CNC software
- Messages and Prompts in the Operator Status Window Status messages
- Abnormal stops (faults)
- CNC syntax errors
- Cutter compensation errors
- Parameter setting errors
- Canned cycle errors
- Miscellaneous errors
- Scaling/Mirroring errors
- 102 Error initializing CPU…cannot continue.
- 103 Error sending setup
- 104 Error sending PID setup
- 105 mpu.plc file read error..cannot continue
- 106 The PC clock appears to be wrong.
- 199 CNC started
- 201 Exiting CNC due to a known error
- 202 Exiting CNC due to a math error
- 204 Exiting CNC…Normal Exit
- 222 Autotune run
- 301 Stopped
- 302 Moving…
- 303 Paused…
- 304 MDI…
- 305 Processing…
- 306 Job finished
- 307 Operator abort: job canceled
- 308 Waiting for input #NN
- 309 Waiting for CYCLE START button
- 310 Waiting for output #NN
- 311 Waiting for memory #NN
- 312 Waiting for PLC operation (Mnn)
- 313 Waiting for dwell time
- 314 Waiting for system #NN
- 315 Searching…
- 317 Waiting for automatic tool change
- 318 Operator Abort probing cancelled
- 319 Probing cycle cancelled
- 320 Probe stuck
- 322 Stall: probing cancelled
- 323 Stall: job cancelled
- 324 Limit: probing cancelled
- 325 Limit: job cancelled
- 326 Fault: probing cancelled
- 327 Fault: job cancelled
- 328 Cutter comp error: job cancelled
- 329 Invalid parameter: job cancelled
- 330 Canned cycle error: job cancelled
- 331 Threading error: job cancelled
- 332 Search Failed
- 334 Locating position to resume job…
- 335 Emergency Stop Released
- 336 Digitize cancelled
- 337 Digitize complete
- 338 Job Cancelled
- 339 Jogging…
- 340 Limit (#__) cleared
- 341 Probing Cycle Finished
- 342 Waiting for motion to stop
- 343 Waiting for stop reason reset
- 344 Feedrate modified due to spindle
- 345 Waiting for spindle to get up to speed
- 346 Waiting for spindle direction
Abnormal stops are detected in the following order: PLC, servo drive, spindle drive, lube, ESTOP. This means that if both the servo drive and the spindle drive have faulted, the servo drive fault message would appear.
- 401 PLC failure detected
- 404 Spindle drive fault detected
- 405 Lubricant level low
- 406 Emergency Stop detected
- 407 limit (#1) tripped
- 408 Programmed action time expired
- 409 _ axis lag
- 410 _ axis position error
- 411 _ axis full power without motion
- 412 _ axis encoder differential error
- 417 Abnormal end of job
- 418 Search Line or Block not found
- 419 Search line in embedded subprogram
- 420 _ axis motor overheating
- 421 Motor(s) too hot: job canceled
- 422 Check Jog Panel cable
- 428 Check MPG cable
- 434 _ idling too high: Releasing power
- 435 _ axis runaway: Check motor wiring
- 436 Servo drive shutdown
- 437 Servo power removed
- 438 Spindle slave position error
- 439 _ axis servo drive data output error
- 441 _ axis overvoltage
- 442 _ axis undervoltage
- 443 _ axis commutation encoder bad
- 444 _ axis overtemperature detected
- 445 _ axis overcurrent detected
- 446 _ axis servo drive data input failure
- 447 _ axis (#) bad index pulse detected
- 449 Manual movement detected in restricted area
- 450 Voltage brake applied
- 451 Current brake applied
- 452 PC Receive Data Error
- 453 CPU Receive Data Error
- 453 Jogging while probe detected
- 454 axis scale encoder differential error
- 455 axis encoder quadrature error
- 456 axis scale encoder quadrature error
- 457 Unable to find home
- 461 Spindle axis is not set
- 462 Triangular Rotary Axis Out of Range
- 487 Invalid tilt table parameters
CNC syntax errors
- 501 Invalid character on line NNNNN
- 502 Invalid G code on line NNNNN
- 503 Invalid M function on line NNNNN
- 504 Invalid parameter on line NNNNN
- 505 Invalid value on line NNNNN
- 506 Only 1 M code per line
- 507 No closing quote
- 508 Macro nesting too deep
- 509 Option not available
- 510 Too many macro arg’s
- 511 Missing parameter
- 513 Expected “=”
- 514 Empty expression
- 515 Syntax error in expression
- 516 Unmatched bracket (parenthesis)
- 517 Evaluation stack overflow
- 518 Undefined variable
- 519 Too many variables
- 520 Invalid variable name
- 521 Divide by zero
- 522 Domain error
- 523 Invalid value in assignment
- 524 Variable is read-only
- 526 M22x Missing initial variable
- 527 M22x initial variable parse error
- 528 M225 String variable not allowed
- 529 M225 invalid variable
- 530 M224 invalid variable
- 531 M22x missing initial quote
- 532 M22x missing end quote
- 533 M22x embedded quote not allowed
- 534 M22x character limit exceeded
- 535 M22x invalid format string
- 536 M22x missing format specifier
- 537 M22x Missing Argument
- 538 M22x argument parse error
- 539 M22x variable type mismatch
- 540 M22x variable cannot be read
- 542 M22x character limit exceeded
- 543 Missing L parameter
- 544 Too many axes
- 545 Value out of range
- 547 Move by counts not allowed
- 548 String too long
- 549 Line too long
- 601 Error: no compensation in MDI
- 603 Arc as first uncomp. move on line NNNNN
- 605 Canned cycle not allowed on line NNNNN
- 606 G53 not allowed on line NNNNN
- 607 Set home not allowed on line NNNNN
- 608 Ref. point move not allowed on line NNNNN
- 701 G10 error: no R-value on line NNNNN
- 702 G10 error: invalid D on line NNNNN
- 703 G10 error: invalid H on line NNNNN
- 704 G10 error: invalid P on line NNNNN
- 705 G10 error: No D, H, or P on line NNNNN
Canned cycle errors
- 801 Error: No R point on line NNNNN
- 802 Error: Q = 0 on line NNNNN
- 803 Error: No Z point on line NNNNN
- 804 Error: Ggg invalid on line NNNNN (gg = 76, 86, 87, 88)
- 805 Error: No Q value on line NNNNN
- 806 Error: No P value on line NNNNN
- 807 Error: Cannot execute G__ when axis B is rotated
- 901 Ref. point invalid on line NNNNN
- 902 No prior G28 or G30 on line NNNNN
- 903 Warning: No coordinates for G50 on line NNNNN
- 905 Warning: 0 radius arc on line NNNNN
- 906 Warning: unknown arc on line NNNNN
- 907 _ axis travel exceeded on line NNNNN
- 909 Program too long: job canceled
- 910 No subroutines in MDI
- 911 Illegal recursion
- 913 Could not open file filename.ext
- 915 DSP window retry sN fN rN
- 916 Unexpected probe contact
- 917 Invalid tilt lookup table
- 918 Probe unable to detect surface
- 919 DSP window failed maximum retries
- 920 Unable to clear obstacle
- 922 Out of memory
- 924 File read error
- 925 Error reading job file
- 926 Failed to locate job continuation position
- 927 Too many subprogram calls
- 928 Error Loading Log Configuration file… Using defaults
- 929 Log Level set to __
- 930 Log Level Configuration file not found… Creating new configuration
- 932 Error during Tool Check
- 933 Log file initialized
- 934 Warning: Excess precision truncated
- 935 _ axis (#) scale disabled
- 936 _ axis (#) scale enabled
- 944 MPU requested resend
- 945 PC requested resend
- 946 PC resending
- 947 PC received data out of order
- 948 PC packet error
- 949 Drive map does not match hardware
