Selca G72 G73 Subprogram modal recall
G72 Cancels subprogram modal recall (G73)
G72
G73 [K...] L...
ParameterDescription
Kworkpiece zero translation request:
K1 the workpiece zero is translated on the points (default).
K2 the workpiece zero is not translated on the points.
Lnumber of the internal subprogram (from L=0 to L=99) or name of the external subprogram (LNAME:)
Warning! The programming order of the K and L parameters must be absolutely respected. Therefore, first program parameter K and then L.
Enabled: until a G72 is programmed.
