Fagor 8037 G Codes M Codes
Fagor 8037M Milling and 8037T Lathe programming G codes / M codes complete lists.
Fagor 8037 M
Fagor 8037M G / M Code List
Fagor 8037M programming G codes / M codes complete lists.
G Codes
G Codes Description
G00 Rapid traverse
G01 Linear interpolation
G02 Clockwise circular (helical) interpolation
G03 Counterclockwise circular (helical) interpolation
G04 Dwell/interruption of block preparation
G05 Round corner
G06 Circle center in absolute coordinates
G07 Square corner
G08 Arc tangent to previous path.
G09 Arc defined by three points
G10 Mirror image cancellation
G11 Mirror image on X axis
G12 Mirror image on Y axis
G13 Mirror image on Z axis
G14 Mirror image in the programmed directions
G15 Longitudinal axis selection
G16 Main plane selection by two addresses and longitudinal axis
G17 Main plane X-Y and longitudinal Z
G18 Main plane Z-X and longitudinal Y
G19 Main plane Y-Z and longitudinal X
G20 Definition of lower work zone limits
G21 Definition of upper work zone limits.
G22 Enable/disable work zones.
G32 Feedrate “F” as an inverted function of time.
G33 Electronic threading
G34 Variable-pitch threading
G36 Controlled corner rounding
G37 Tangential entry
G38 Tangential exit
G39 Chamfer
G40 Cancellation of tool radius compensation
G41 Left-hand tool radius compensation
G41 N Collision detection
G42 Right-hand tool radius compensation
G42 N Collision detection
G43 Tool length compensation
G44 Cancellation of tool length compensation
G50 Controlled corner rounding
G51 Look-Ahead
G52 Movement until making contact
G53 Programming with respect to machine zero
G54 Absolute zero offset
G55 Absolute zero offset
G56 Absolute zero offset
G57 Absolute zero offset
G58 Additive zero offset
G59 Additive zero offset
G60 Multiple machining in a straight line
G61 Multiple machining in a rectangular pattern
G62 Grid pattern canned cycle
G63 Multiple machining in a circular pattern
G64 Multiple machining in an arc
G65 Machining programmed with an arc-chord
G69 Drilling canned cycle with variable peck
G70 Programming in inches
G71 Programming in millimeters
G72 General and specific scaling factor
G73 Pattern rotation
G74 Home search
G75 Probing move until touching
G76 Probing move while touching
G79 Canned cycle parameter modification
G80 Canned cycle cancellation
G81 Drilling canned cycle
G82 Drilling canned cycle with dwell
G83 Deep-hole drilling canned cycle with constant peck
G84 Tapping canned cycle
G85 Reaming canned cycle
G86 Boring canned cycle with withdrawal in G00
G87 Rectangular pocket canned cycle.
G88 Circular pocket canned cycle
G89 Boring canned cycle with withdrawal in G01
G90 Absolute programming
G91 Incremental programming
G92 Coordinate preset / spindle speed limit
G93 Polar origin preset
G94 Feedrate in millimeters (inches) per minute
G95 Feedrate in millimeters (inches) per revolution.
G96 Constant cutting point speed
G97 Constant tool center speed
G98 Withdrawal to the starting plane at the end of the canned cycle
G99 Withdrawal to the reference plane at the end of the canned cycle
G159 Absolute zero offsets
G210 Bore milling canned cycle
G211 Inside thread milling canned cycle.
G212 Outside thread milling canned cycle.
M Codes
M Codes Description
M00 Program stop
M01 Conditional program stop
M02 End of program
M03 Clockwise spindle rotation
M04 Counterclockwise spindle rotation
M05 Spindle stop
M06 Tool change code
M19 Spindle orientation
M41, M42, M43, M44 Spindle gear change
M30 End of program with return to the first block
Addresses
Addresses Description
F Machining feedrate
S Spindle speed
T Tool number
D Tool offset number
Fagor 8037T G / M Code List
Fagor 8037T Lathe programming G codes / M codes complete lists.
G Codes
G Codes Description
G00 Rapid traverse
G02 Clockwise circular interpolation
G03 Counterclockwise circular interpolation
G05 Round corner
G07 Square corner
G38 Tangential exit
G39 Chamfer
G51 Look-Ahead
G66 Pattern repeat cycle canned cycle
G68 X axis roughing canned cycle
G69 Z axis roughing canned cycle
G74 Home search
G81 Turning canned cycle for straight sections
G82 Facing canned cycle for straight sections
G83 Drilling canned cycle
G84 Turning canned cycle for curved sections
G85 Facing canned cycle for curved sections
G86 Longitudinal threading canned cycle
G87 Face threading canned cycle
G88 X axis grooving canned cycle
G89 Z axis grooving canned cycle
G90 Absolute programming:
G96 Constant surface speed
G97 Spindle speed in RPM
G151 Programming the X axis in diameter.
G152 Programming the X axis in radius.
G233 Withdrawal of axes when interrupting a threading operation.
M Codes
M Codes Description
M00 Program stop
M02 End of program
M05 Spindle stop
Addresses
S Spindle speed
T Tool number
