Fagor 8065 G Codes M Codes
Fagor 8065M Milling and 8065T Lathe programming G codes / M codes complete lists.
Fagor 8065
Fagor 8065M G / M Code List
Fagor 8065M programming G codes / M codes complete lists.
G Codes
G CodesDescription
G00Rapid traverse.
G01Linear interpolation.
G02Clockwise circular (helical) interpolation.
G03Counterclockwise circular (helical) interpolation.
G04Dwell
G05Controlled corner rounding (modal).
G06Arc center in absolute coordinates (not modal).
G07Square corner (modal).
G08Arc tangent to previous path.
G09Arc defined by three points.
G10Mirror image cancellation.
G11Mirror image on X.
G12Mirror image on Y.
G13Mirror image on Z.
G14Mirror image in the programmed directions.
G17Main plane X-Y, and longitudinal axis Z.
G18Main plane Z-X, and longitudinal axis Y.
G19Main plane Y-Z, and longitudinal axis X.
G20Main plane by two directions and longitudinal axis.
G30Polar origin preset.
G31Temporary polar origin shift to the center of arc.
G33Electronic threading with constant pitch.
G36Automatic radius blend.
G37Tangential entry.
G38Tangential exit.
G39Automatic chamfer blend.
G40Cancellation of tool radius compensation.
G41Left-hand tool radius compensation.
G42Right-hand tool radius compensation.
G45Turn tangential control on and off.
G50Semi-rounded corner.
G53Zero offset cancellation.
G54Absolute zero offset 1.
G55Absolute zero offset 2.
G56Absolute zero offset 3.
G57Absolute zero offset 4.
G58Absolute zero offset 5.
G59Absolute zero offset 6.
G60Square corner (not modal).
G61Controlled corner rounding (not modal).
G63Rigid tapping.
G70Programming in inches.
G71Programming in millimeters.
G72Scaling factor.
G73Coordinate system rotation.
G74Home search
G80Canned cycle cancellation.
G81Drilling canned cycle.
G82Drilling canned cycle with a variable peck.
G83Deep-hole drilling canned cycle with constant peck.
G84Tapping canned cycle.
G85Reaming canned cycle.
G86Boring canned cycle.
G87Rectangular pocket canned cycle.
G88Circular pocket canned cycle.
G90Programming in absolute coordinates.
G91Programming in incremental coordinates.
G92Coordinate preset.
G93Machining time in seconds.
G94Feedrate in millimeters/minute (inches/minute).
G95Feedrate in millimeters/revolution (inches/revolution).
G96Constant surface speed.
G97Constant turning speed.
G98Withdrawal to the starting plane.
G99Withdrawal to the reference plane.
G100Probing until making contact.
G101Include probe offset.
G102Exclude probe offset.
G103Probing until not making contact.
G104Probe movement up to the programmed position.
G108Feedrate blending at the beginning of the block.
G109Feedrate blending at the end of the block.
G112Changing of parameter range of an axis.
G130Percentage of acceleration to be applied per axis or spindle.
G131Percentage of acceleration to be applied to all the axes.
G132Percentage of jerk to be applied per axis or spindle.
G133Percentage of jerk to be applied to all the axes.
G134Percentage of Feed-Forward to be applied.
G135Percentage of AC-Forward to be applied.
G136Circular transition between blocks.
G137Linear transition between blocks.
G138Direct activation/cancellation of tool compensation.
G139Indirect activation/cancellation of tool compensation.
G145Freeze tangential control.
G151Programming in diameters.
G152Programming in radius.
G157Excluding axes in the zero offset.
G158Incremental zero offset.
G159Additional absolute zero offsets.
G160Multiple machining in straight line.
G161Multiple machining in rectangular pattern.
G162Multiple machining in grid pattern.
G163Multiple machining in a full circle.
G164Multiple machining in arc pattern.
G165Machining programmed with an arc-chord.
G170Hirth axes OFF
G171Hirth axes ON
G174Set the machine coordinate.
G180/G189OEM subroutine execution.
G380/G399OEM subroutine execution.
G192Turning speed limit.
G193Interpolating the feedrate.
G196Constant cutting point feedrate.
G197Constant tool center feedrate.
G198Setting of lower software travel limits
G199Setting of upper software travel limits
G200Exclusive manual intervention.
G201Activation of additive manual intervention.
G202Cancellation of additive manual intervention.
G210Bore milling canned cycle.
G211Inside thread milling cycle.
G212Outside thread milling cycle.
G261Arc center in absolute coordinates (modal).
G262Arc center referred to starting point.
G263Arc radius programming.
G264Cancel arc center correction.
G265Activate arc center correction.
G266Feedrate override at 100%
M Codes
M CodesDescription
M00Program stop.
M01Conditional program stop.
M02End of program.
M03Start the spindle clockwise.
M04Start the spindle counterclockwise.
M05Stop the spindle.
M06Tool change.
M17End of a global or local subroutine.
M19Spindle orientation.
M29End of a global or local subroutine.
M30End of program.
M41-M44Gear change.
Addresses
AddressesDescription
/Block skip condition.
#Programming instructions.
$Flow controlling instructions.
%Program header.
;(semi-colon) Block comment .
[ ]Text type block label.
NNumber type block label.
GPreparatory functions.
X~CPosition of the axes.
FFeedrate of the axes.
SSpindle speed.
TTool number.
DTool offset number.
MAuxiliary functions.
HAuxiliary functions.
NRNumber of block repetitions.
( )Block comment.
Fagor 8065T G / M Code List
Fagor 8065T programming G codes / M codes complete lists.
G Codes
G CodesDescription
G00Rapid traverse.
G04Dwell
G38Tangential exit.
G63Rigid tapping.
G66Pattern repeat canned cycle.
G68Stock removal cycle along X axis.
G69Stock removal canned cycle along Z axis.
G72Scaling factor.
G74Home search
G81Turning canned cycle with straight sections.
G82Facing canned cycle with straight sections.
G83Drilling / tapping canned cycle.
G84Turning canned cycle with arcs.
G85Facing canned cycle with arcs.
G86Longitudinal threading canned cycle.
G87Face threading canned cycle.
G88Grooving canned cycle along the X axis.
G89Grooving canned cycle along the Z axis.
G160Drilling / tapping canned cycle on the face of the part.
G161Drilling / tapping canned cycle on the side of the part.
G162Slot milling canned cycle along the side of the part.
G163Slot milling canned cycle along the face of the part.
G170Hirth axes OFF
G171Hirth axes ON
M Codes
M CodesDescription
M00Program stop.
M02End of program.
M06Tool change.
M30End of program.
M41-M44Gear change.
Addresses
%Program header.
SSpindle speed.
TTool number.
( )Block comment.
