Mazak G Codes (T Series)
Mazak G code list for cnc machinists who work on Mazak INTEGREX 300/400-III/III T/IIIS/IIIST cnc machines.
MAZAK Integrex 400 III ST
Mazak G Codes
G Code Function
G00 Positioning
G01 Linear interpolation
G01.1 Threading with C-axis interpolation
G02 Circular interpolation (CW)
G03 Circular interpolation (CCW)
G02.1 Spiral interpolation (CW)
G03.1 Spiral interpolation (CCW)
G04 Dwell
G05 High-speed machining mode
G06.1 Fine spline interpolation
G06.2 NURBS interpolation
G07 Virtual-axis interpolation
G07.1 Cylindrical interpolation
G09 Exact-stop check
G10 Data setting mode ON
G10.1 Command address OFF
G11 Data setting mode OFF
G12.1 Polar coordinate interpolation ON
G13.1 Polar coordinate interpolation OFF
G17 X-Y plane selection
G18 Z-X plane selection
G19 Y-Z plane selection
G20 Inch command
G21 Metric command
G22 Pre-move stroke check ON
G23 Pre-move stroke check OFF
G27 Reference point check
G28 Reference point return
G29 Return from reference point
G30 Return to 2nd, 3rd and 4th reference points
G31 Skip function
G31.1 Multi-step skip 1
G31.2 Multi-step skip 2
G31.3 Multi-step skip 3
G32 Thread cutting (straight, taper)
G34 Variable lead thread cutting
G234.1 Hole machining pattern cycle (on a circle)
G235 Hole machining pattern cycle (on a line)
G236 Hole machining pattern cycle (on an arc)
G237.1 Hole machining pattern cycle (on a grid)
G40 Nose R/Tool radius compensation OFF
G41 Nose R/Tool radius compensation (left)
G41.2 3-D tool radius compensation (left)
G42 Nose R/Tool radius compensation (right)
G42.2 3-D tool radius compensation (right)
G43.4 Tool tip point control (Type 1) ON
G43.5 Tool tip point control (Type 2) ON
G50 Coordinate system setting/Spindle clamp speed setting
G50.2 Polygonal machining mode OFF
G51.2 Polygonal machining mode ON
G52 Local coordinate system setting
G52.5 MAZATROL coordinate system cancel
G53 Machine coordinate system selection
G53.5 MAZATROL coordinate system selection
G54 Selection of workpiece coordinate system 1
G55 Selection of workpiece coordinate system 2
G56 Selection of workpiece coordinate system 3
G57 Selection of workpiece coordinate system 4
G58 Selection of workpiece coordinate system 5
G59 Selection of workpiece coordinate system 6
G54.1 Additional workpiece coordinate systems
G60 One-way positioning
G61 Exact stop mode
G61.1 High-accuracy mode (Geometry compensation)
G62 Automatic corner override
G63 Tapping mode
G64 Cutting mode
G65 User macro single call
G66 User macro modal call A
G66.1 User macro modal call B
G67 User macro modal call OFF
G68.5 3-D coordinate conversion ON
G69.5 3-D coordinate conversion OFF
G70 Finishing cycle
G71 Longitudinal roughing cycle
G72 Transverse roughing cycle
G73 Contour-parallel roughing cycle
G74 Longitudinal cut-off cycle
G75 Transverse cut-off cycle
G76 Compound thread-cutting cycle
G80 Fixed cycle OFF
G83 Front driling cycle
G84 Front tapping cycle
G84.2 Front synchronous tapping cycle
G85 Front boring cycle
G87 Outside driling cycle
G88 Outside tapping cycle
G88.2 Outside synchronous tapping cycle
G89 Outside boring cycle
G90 Fixed cycle A (Longitudinal turning cycle)
G92 Threading cycle
G94 Fixed cycle B (Transverse turning cycle)
G93 Inverse time feed
G96 Constant peripheral speed control ON
G97 Constant peripheral speed control OFF
G98 Feed per minute (asynchronous)
G99 Feed per revolution (synchronous)
G109 Single program multi-system control
G110 Cross machining control ON
G111 Cross machining control OFF
G112 M, S, T, B output to opposite system
G113 Hob milling mode OFF
G114.3 Hob milling mode ON
G122 Polar coordinate input ON
G123 Polar coordinate input OFF
G122.1 X-axis radial command ON
G123.1 X-axis radial command OFF
—G130 Tornado cycle
G136 Measurement macro, workpiece/coordinate measurement
G137 Compensation macro
