The fastener torque settings on your CNC machine tool are critical to it’s life span and the accuracy of your finished product. Get it right every time with Torque Screw driver
Adjustable torque drivers can be used anywhere the proper torque setttings are desired.
One of the most common problems CNC shops face is that of non-uniform tightening of insert tips of cutters if tightened with ordinary screw drivers, a result of which is improper cut surface and out of tolerance job dimensions.
Torque can be very easily adjusted.
No over torquing is possible as after achieving set torque it starts to slip.
Various screw driver blades are available like Torx and Torx Plus (IP).
More Info about Torque Screw driver
Torque Screw Drivers For CNC Machinists
