Yes of course, Insert DCMT comes in variety of cutting radius to suit every ones needs.
CNC Turning Insert DCMT
I like DCMT 11T308 and try to use it where ever possible because of its small size. DCMT11T308 has a radius of 0.8mm which can be used for a bit bigger cuts due to its solid shape compare to VBMM 160408. Although DNMG 110408 is a good alternative if possible.
DCMT 11T308 is a good possibility for boring smaller but harder jobs. And if DCMT 11T308 is compared to DNMG 110408 for boring smaller jobs the DNMG 110408 will be behind due to its 0° degree clearance angle which is not suitable for smaller boring. I have used DCMT 11T308 on Aluminum to Steel components but it never disappoints me.
CNC Turning Insert DCMT for Best Surface Finish
