Sandvik Coromant Insert Identifier App for iPhone, Android and blackberry helps you find which Sandvik Coromant solution is equivalent to the insert you currently use. It will guide you when you are uncertain of which Sandvik Coromant grades and geometries are available.
Results given are based on a direct equivalent to the grade/geometry you input. Optimization of your machining process may provide several alternatives.
