Sinumerik Alarm 75600 Channel %1 retrace support: wrong MD configuration. Error code %2
%2 = Error code
The following errors were detected in the machine data of the retrace support function when starting up:
Error code = 4 Machine data MM_NUM_CC_BLOCK_ELEMENTS must be increased.
Error code = 5 Insufficient compile cycle heap memory available. Adjust machine data $MC_RESU_RING_BUFFER_SIZE, $MC_RESU_SHARE_OF_CC_HEAP_MEM and $MC_MM_NUM_CC_HEAP_MEM.
Error code = 6 The machine data $MN_ASUP_START_MASK and $MN_ASUP_START_PRIO_LEVEL are not set correctly.
Correct machine data.
