Sinumerik Alarm 4340 Channel %1 block %2 invalid transformation type in transformation no. %3
%3 = Transformation number
An invalid, i.e. undefined, number was entered in one of the machine data TRAFO_TYPE_1 … TRAFO_TYPE_8. This alarm also occurs if a certain type of transformation is only impossible on the type of control used (e.g. 5-axis transformation on a SINUMERIK 802D).
Enter a valid transformation type.
