Sinumerik Alarm 311717 Axis %1 drive %2 SSI transmission timeout
%1 = NC axis number
SSI transmission must be able to finish within one position control cycle. This is not possible with its current parameterization.
– Mode group not ready.
Either increase the position control cycle of the NC or increase the SSI transmission rate (MD_5011 $MD_ACTUAL_VALUE_CONFIG bits 14 and 15). The following transmission rates are possible: 100 kHz, 500 kHz, 1 MHz and 2 MHz. Notice: It might be possible that the length of the encoder cable does not allow an increase in frequency!
