Sinumerik Alarm 301719 Axis %1 drive %2 power section data incomplete
%1 = NC axis number
The data for the power section are incomplete:
• Operation of a power section with an FDD motor requires: MD_1178 $MD_INVERTER_DERATING_SYN (derating factor at 8kHz)
• Operation of a power section with an MSD motor requires: MD_1179 $MD_INVERTER_DERATING_ASYN (derating factor at 8kHz)
• Operation of a power section with a PE MSD motor requires: MD_1179 $MD_INVERTER_DERATING_ASYN (derating factor at 8kHz)
• MD_1175 $MD_INVERTER_THERM_CURR_ASYN (limit current power section for PE MSD)
• MD_1177 $MD_INVERTER_RATED_CURR_ASYN (limit current power section for PE MSD).
– Mode group not ready.
Carry out new start-up with power section selection or enter the following data:
• MD_1178 $MD_INVERTER_DERATING_SYN (derating factor at 8kHz)
• MD_1179 $MD_INVERTER_DERATING_ASYN (derating factor at 8kHz)
