Sinumerik Alarm 300786 Axis %1 drive %2 field weakening speed invalid
%1 = NC axis number
The value in MD 1142: $MD_FIELD_WEAKENING_SPEED (threshold speed for field weakening) is less than or equal to zero. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
• For standard motors: Reset the drive (delete the bootfile) and repeat the startup.
• For third-party motors: Check and, if necessary, refer to the motor data sheet to correct MD 1142: $MD_FIELD_WEAKENING_SPEED (threshold speed for field weakening).
