Sinumerik Alarm 300780 Axis %1 drive %2 zero load current > rated motor current
%1 = NC axis number
The no-load current of the motor (MD 1136: $MD_MOTOR_NOLOAD_CURRENT) has been set at a greater value than the rated current of the motor (MD 1103: $MD_MOTOR_NOMINAL_CURRENT). The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
• For standard motors: Reset the drive (delete the bootfile) and repeat the startup.
• For third-party motors: Check and, if necessary, refer to the motor data sheet to correct machine data MD 1103: $MD_MOTOR_NOMINAL_CURRENT (rated motor current) and MD 1136: $MD_MOTOR_NOLOAD_CURRENT (motor no-load current).
