Sinumerik Alarm 300756 Axis %1 drive %2 speed hysteresis of setpoint current smoothing invalid
%1 = NC axis number
The value in MD 1246: $MD_CURRENT_SMOOTH_HYSTERESIS $MD_CURRENT_SMOOTH_HYSTERESIS (hysteresis of the speed-dependent M set- point smoothing) is greater than or equal to the value in MD 1245: $MD_CURRENT_SMOOTH_HYSTERESIS (threshold of the speed-dependent M set- point smoothing).
Please inform the authorized personnel/service department. Check and, if necessary, correct the torque adaptation factor MD 1246: $MD_CURRENT_SMOOTH_HYSTERESIS (hysteresis of the speed-dependent M setpoint smoothing) or MD 1245: $MD_CURRENT_SMOOTH_HYSTERESIS (threshold of the speed-dependent M set- point smoothing). $MD_CURRENT_SMOOTH_SPEED.
