Sinumerik Alarm 300613 Axis %1 drive %2 maximum permissible motor temperature exceeded
%1 = NC axis number
The motor temperature (measured via the temperature sensor KTY 84 and fed to the module through the motor encoder cable) has exceeded the temperature limit in drive MD 1607: $MD_MOTOR_TEMP_SHUTDOWN_LIMIT (motor temperature shutdown limit). The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
• Motor overloaded.
• Check the motor data. Possibly the machine current was too high as a result of incorrect motor data.
• Check the temperature sensor (2nd sensor possible with MSD).
• Check the motor encoder cable.
• Motor encoder defective.
• Check the motor fan.
• Check the acceleration.
• If necessary, use a higher-performance motor.
• Winding fault in motor.
• 611D control module defective.
• Modify MD 1230: $MD_TORQUE_LIMIT (1st torque limit), MD 1235: POWER_LIMIT (1st power limit) set too high.
