Sinumerik Alarm 300502 Axis %1 drive %2 maximum current monitoring of phase current R
%1 = NC axis number
The phase current R is greater than or equal to 1.05 times the maximum power section current MD 1107: $MD_INVERTER_MAX_CURRENT (transistor limit current).
– Mode group not ready.
• Check max. power section current in MD 1107 $MD_INVERTER_MAX_CURRENT (transistor limit current)
• Check the motor data (motor code)
• Motor has ground or winding fault
• Check the controller data
• Check the power section and motor terminals (including motor protection)
• Error in actual current measurement (if necessary, replace 611D power section or controller module)
