Sinumerik Alarm 300010 Axis %1 drive %2 active without NC axis assignment
%1 = NC axis number
A drive is active that is not used/addressed by any NC axis (actual value, setpoint). All active drives must be assigned to an axis with respect to the setpoint value or the actual value.
Please inform the authorized personnel/service department. Check the configuration data, the assignment of setpoints and actual values for the drive motor and the position encoder.
MDs for the drive configuration:
• Modify MD 13000: DRIVE_IS_ACTIVE
• Modify MD 13010: DRIVE_LOGIC_NR
• Modify MD 13020: DRIVE_INVERTER_CODE
• Modify MD 13030: DRIVE_MODULE_TYPE
• Modify MD 13040: DRIVE_TYPE
MDs for the setpoint/actual-value assignment:
• Modify MD 30110: CTRLOUT_MODULE_NR
• Modify MD 30130: CTRLOUT_TYPE
• Modify MD 30220: ENC_MODULE_NR
• Modify MD 30230: ENC_INPUT_NR
• Modify MD 30240: ENC_TYPE
It might be necessary to first declare an NC axis in the channel for this drive (MD 20070 AXCONF_MACHAX_USED = K, [K …channel axis no.]).
