Sinumerik Alarm 20143 Channel %1 axis %2 command axis cannot be started as it is controlled by the PLC
%1 = Channel number %2 = Axis name, spindle number
An attempt has been made to start a command axis by means of a block-related or modal synchronous action. This start is not possible as the axis is controlled by the PLC.
End control of the axis by the PLC and therefore return it to the channel or start the command axis with a static synchronous action.
