Sinumerik Alarm 17193 Channel %1 block %2 the active tool is no longer on toolholder no./spindle no. %3, program %4
%3 = Toolholder no., spindle no.
%4 = Program name
The tool at the specified toolholder/spindle at which the last tool change was carried out as master toolholder or master spindle, has been replaced. Example: N10 SETHTH(1) N20 T=”Wz1″ ; Tool change at master toolholder 1 N30 SETMTH(2) N40 T1=”Wz2″ ; Toolholder 1 is only a secondary toolholder. Changing the tool does not result in correction deselection. N50 D5; New correction selection. At present, there is no active tool which D can refer to, i.e. D5 refers to T no. = 0, which results in zero correction.
• Modify program:
• Set desired spindle as master spindle or toolholder as master toolholder.
• Then, if required, reset master spindle or master toolholder.
