Sinumerik Alarm 16797 Channel %1 block %2 coupling is active
An operation is to be performed in which no coupling may be active, e.g. COUPDEL or TANGDEL must not be used on active couplings.
Correct NC part program, deselect the link with COUPOF or TANGOF.
