Sinumerik Alarm 16785 Channel %1 block %2 identical spindles/axes %3
A coupling has been switched on in which the following spindle/axis is identical to the master spindle/axis.
Please inform the authorized personnel/service department. • Configure link accordingly in MD (channel MD: COUPLE_AXIS_n) • or modify part program.
