Sinumerik Alarm 16762 Channel %1 block %2 spindle %3 thread function is active
%3 = Spindle number
Mistake in programming: The spindle function cannot be executed at the present time. This alarm occurs when the spindle (master spindle) is linked with the axes by an interpolation function.
Modify part program. Deselect thread cutting or tapping.
