Sinumerik Alarm 16761 Channel %1 block %2 axis/spindle %3 not programmable in the channel
Mistake in programming: The axis/spindle cannot be programmed in the channel at this time. This alarm can occur when the axis/spindle is being used by another channel or by the PLC.
Modify part program, use “GET()”.
