Sinumerik Alarm 14800 Channel %1 block %2 programmed path speed less or equal to zero
A negative F value has been programmed in conjunction with the G functions G93, G94, G95 or G96. The path velocity may be programmed in the range 0.001 to 999 999.999 [mm/min, mm/rev, deg/min, deg/rev] for the metric input system and 0.000 1 to 39 999.999 9 [inch/min, inch/rev] for the inch input system.
Program the path velocity (geometric sum of the velocity components of the geometry axes involved) within the limits given above.
