Sinumerik Alarm 14755 Channel %1 block %2 motion synchronous actions without traverse motion
The programmed motion synchronous action and the function “Several feeds” require a traversing motion or the value of the traversing motion is 0. This alarm is no longer used after P3.2.
Modify part program.
