Sinumerik Alarm 14122 Channel %1 block %2 angle and direction of the cone programmed
With taper circumference interpolation of orientation with ORICONCW and ORICC, only the opening angle or the direction of the taper may be programmed. Programming of both in one single block is not allowed.
Modify part program.
