Sinumerik Alarm 14050 Channel %1 block %2 nesting depth for arithmetic operations exceeded
For calculating arithmetic expressions in NC blocks, an operand stack with a fixed set size is used. With very complex expressions, this stack can overflow.
Divide up complex arithmetic expressions into several simpler arithmetic blocks.
