Sinumerik Alarm 112502 Insufficient memory, abort in line %1
%1 = Line number
The program cannot interpret a program block with contour programming. Contour not in the directory. Program is not loaded. The program cannot interpret a program block with contour programming. Contour not in the directory.
– Alarm display. Remedy: Load contour into the directory. Load contour into the directory.
Internal
