Sinumerik Alarm 112201 The contour is a step in the current automatic sequence. Machining not enabled
The contour is an element of a program loaded under “Machine auto” and cannot be deleted or renamed. After the program has been started, the integrated contours cannot be changed under “Program” while the program is running.
Stop the program and load it under “Program”. Remove the contour from the program.
Internal
