Sinumerik Alarm 111006 Maximum number of contour elements exceeded %1
%1 = Contour name
The maximum permissible number of 50 contour elements was exceeded when interpreting the machining sequence of a contour.
Check the contour’s machining sequence and, if necessary, edit it.
Internal
