Sinumerik Alarm 10950 Channel %1 calculation of arc length function too inaccurate
The calculation of the arc length function could not be performed to the required accuracy.
– Warning display.
The calculation of the arc length function could not be performed to the required accuracy during active polynomial interpolation. Either increase MD SPLINE_FEED_PRECISION or reserve more memory for the representation of the arc length polynomials. MD MM_ARCLENGTH_SEGMENTS defines how many polynomial segments can be used per block in order to approximate the arc length function.
