Sinumerik Alarm 8045 Option for selected cycle settings not set
The option for the 810D Powerline for activation of the same current/speed/position con- troller/IPO cycle time grid as with the 840D is not set. Without the option, only the set values of the 810D Standard are permitted.
• Buy option
• Set (current/speed controller) cycle times to 810D default values.
