Sinumerik Alarm 20057 Channel %1 block %2 revolutional feedrate for axis/spindle %3 is <= zero
Revolutional feed has been programmed for an axis/spindle, but the velocity was not programmed or the programmed value is smaller than or equal to zero.
– Local alarm reaction.
• Correct the part program or
• Specify the correct feed for PLC axes at the VDI interface,
• Specify feed for oscillating axes in the setting data $SA_OSCILL_VELO.
