Sinumerik Alarm 112045 Several insertion points required
Several insertion points are required for machining the contour pocket. The machining breaks up into several individual machinings. The program can be started. This alarm is only a warning. Residual material will remain.
By using a smaller milling cutter, the machining could be done with an insertion point.
Internal
