Sinumerik Alarm 111430 Program not loaded. Error when converting old cycles in G code. No NC memory.
In previous ManualTurn versions, LINE, INCLINED and CIRCLE steps were saved as cycles. Now these are saved as G codes (INCLINED, CIRCLE without angle programming). When loading a sequence, a check is run to see whether old cycles were used. If there are old cycles, the sequence is converted and saved again in the NC. This alarm is output if an error occurs thereby (memory full).
Alarm display.
There must be enough memory for the original sequence and for the backup copy in order for the sequence to be created.
Internal
