Haas Setting 90 Graph Z Zero Location – Haas Lathe
Haas Setting Description
This setting adjusts for extreme values in tool geometry or shift values. In graphics, tool offsets are ignored so that the cutting paths of different tools are displayed in the same location. Setting this to an approximate value of machine coordinates for the programmed part zero will void any Z Over Travel Range alarms that you may encounter in graphics. The default is -8.0000.
