Haas Setting 28 Can Cycle Act w/o X/Z – Haas Lathe
Haas Setting Description
Turning this setting On will cause the commanded canned cycle to complete without an X or Z command. The preferred method of operation is with this setting On.
When this setting is Off, the control will stop if a canned cycle is programmed without an X or Z axis move.
