Haas Parameter 838 SPINDLE ORIENT LOW PASS FILTER CUTOFF FREQUENCY
When the spindle is in orientation mode, this parameter enables the torque low pass filter to reduce high-frequency noise or vibration. The value is in Hz from 1 to 500. This parameter works in conjunction with parameter 176 bits 12 and 13. When Parameter 838 is set to zero, these bits are used in calculations.
