Haas Parameter 819 SPINDLE LUBE TIME INTERVAL
Specifies the maximum number of minutes of spindle run-time, after which the spindle will be lubricated. No lubrication will be done if the machine is not running. This parameter is activated when parameter 817 is 2.
