Haas Parameter 734 INPUT MASK (Used for the Office Mills) – Haas Mill
0 TOOL CHANGER IN .
1 TOOL CHANGER OUT .
2 TOOL #1 IN POSITION .
3 LOW TSC PRESSURE .
4 TOOL IN POSITION .
5 SPINDLE HIGH GEAR .
6 SPINDLE LOW GEAR .
7 RESERVED .
8 RESERVED .
9 M-CODE FINISH .
10 BUSS PWR FAULT .
11 LOW AIR PRESSURE .
12 LOW LUBE PRESSURE .
13 REGEN. OVERHEAT .
14 DRAWBAR OPEN .
15 DRAWBAR CLOSED .
16 SPARE .
17 SPARE .
18 SPARE .
19 SPARE .
20 LOW TRANS OIL PRESS .
21 APC DOOR .
22 APC PIN CLEAR #1 .
23 APC PIN CLEAR #2 .
24 TOOL UNCLAMP REMOTE .
25 SPARE .
26 APC PALLET #2 HOME .
27 APC PALLET #1 HOME .
28 GROUND FAULT .
29 G31 BLOCK SKIP .
30 SPIGOT POSITION .
31 CONVEYR OVERCURRENT
