Haas Parameter 734 INPUT MASK (Used for the Office Lathes) – Haas Lathe
0 TOOL TURRET UNLOCKD .
1 TOOL TURRET LOCKED .
2 C AXIS DISENGAGED .
3 SPARE .
4 C AXIS ENGAGED .
5 SPINDLE HIGH GEAR .
6 SPINDLE LOW GEAR .
7 EMERGENCY STOP .
8 DOOR SWITCH .
9 M-CODE FINISH .
10 BUSS PWR FAULT .
11 LOW AIR PRESSURE .
12 LOW LUBE PRESSURE .
13 REGEN OVERHEAT .
14 LOW TRANS OIL PRESS .
15 SPARE .
16 SPINDLE LOCK .
17 SPINDLE FAULT .
18 SPINDLE STOPPED .
19 SPINDLE AT SPEED .
20 LOW HYDRAULIC PRESS .
21 TAILSTOCK FOOT SW .
22 PROBE NOT HOME .
23 SPARE .
24 TOOL UNCLAMP REMOTE .
25 SPARE .
26 BRFEED EOB/SB LB SW .
27 BRFEED Flt/SB PR SW .
28 GROUND FAULT .
29 G31 BLOCK SKIP
30 BRFEED SP LK/SB EOB .
31 CONVEYR OVERCURRENT
