Haas Parameter 731 PWR FAULT MAX TIME
Parameters 730 and 731 support the optional Power Failure Detect Module. Parameter 730, Pwr Fault Threshold units are an analog to digital value. Parameter 731, Pwr Fault Max Time units are millisecond/20. If the Power Failure Detection Module is not installed, Parameters 730 and 731 should both be set to zero.
