Haas Parameter 692 STEADY REST OUTPUT – Haas Lathe
Supports the steady rest option. If a lathe has the option, it must be set to the output relay number that activates the clamping mechanism. This number can be 32 through 55 for relays #1132 through #1155, respectively. For lathes without the steady rest option, it must be zero.
