Haas Parameter 656 X INDEXER DWN TIMEOUT
Supports indexer rotary table. It specifies time (in ms) allowed for seeking indexer Down-switch. If switch is not detected within allowed time, Alarm 960, Indexer Switch not Found in Time is generated. When it is set to zero, the feature is bypassed. Parameter 69, Air Brake Delay is used as allowed time for seeking the Up-switch. If switch is not detected within the allowed time, Alarm 925, A Indexer is not Fully in the Up Position is generated.
