Haas Parameter 616 SS LUBE CYCLE TIME – Haas Lathe
Supports the VTC-48. It controls the subspindle lubrication in the same manner as Parameter 117. The units are 50ths of a second. If a subspindle low lube condition is found, Alarm 121, Low Lube or Low Pressure is generated and both the main spindle and the subspindle are shut down. It should be set to 108000.
