Haas Parameter 48 A MAX TRAVEL (Negative Travel Limit) (Steps)
See Parameter 6 for description. Normally this parameter would not apply to the A axis; however, this parameter is used on mills with a gimbaled spindle (5-axis mills). On a VR-series mill, this parameter is used to limit the amount of angular movement of the spindle (A and B axes). The A and B axes are limited in movement to a distance between negative Max Travel, and positive Tool Change Offset. On 5-axes mills A- and B-axis Rot Trvl Lim must be set to 1, Max Travel and Tool Change Offset must be calibrated and set correctly.
