Haas Parameter 308 ARM ROTATE TIME – Haas Mill
Supports the side-mount tool changers. It specifies the time allowed (in milliseconds) for the arm to rotate to the next position. The positions are, Clamp, Unclamp, and Origin. If the arm does not move to the commanded position within the allowed time, Alarm 622, Tool Arm Fault is generated. For mills without a side-mount tool changer, this parameter should be set to 0.
