Haas Parameter 258 COLD SPINDLE TEMP – Haas Mill
The first time Cycle Start is pressed after the machine has been turned on, control compares microprocessor temperature (in degrees Fahrenheit) against value of this parameter. If microprocessor is colder, control assumes spindle is too cold or inadequately lubricated to be run safely at high speed and the following message is displayed:
!!!WARNING!!!
YOUR MACHINE IS COLD, RUN A WARM-UP PROGRAM BEFORE RUNNING THE SPINDLE AT HIGH SPEED
OR DAMAGE MAY RESULT
PRESS ‘CANCEL’ TO CONTINUE
The user must press Cancel before continuing. It is recommended that a spindle warm-up program be run immediately. This message will only appear once each time the machine has been turned on. The initial value for this parameter is 70 (degrees F). To disable this feature, change it to zero.
